mlrsmasterguns
- Reidsville, N.C.
What vehicle come from the factory with Fram filters installed?
Zuki-Ron, if you really are interested in this subject, why not do some more cutting up, this time with a few comparable Jeep filters? I did this some years ago, and the differences were quite apparent. You may still decide Frams are good enough, but if you're honest you won't be able to say they're the same.
I recommend that for your next 12 thousand miles or so, you buy, in succession, a Fram, a Wix, a Bosch, and a K&N. Use the same oil every time, and run each for three thousand miles. Make a note of the oil pressure readings when filter is new, and just before the change. When all four are used up, cut them open and compare. Look at the material, the support, the number of pleats, and the design of the anti-drainback valve.
I wouldn't take your word for it. Don't take mine. Look for yourself.
You should always take pressure statements, including mine, with a grain of salt, since so many factors - temperature, oil brand, filter age, and even probably the phase of the moon, can influence the reading by a few pounds. Mine are anecdotal for sure, but I believe from them that the best filters will provide a little better flow for a little longer.i kind of appreciate hearing peoples opinions. of course i take nothing on the net as FACT. always check n see for urself. i just replaced my oil filter with a napa gold im glad i made a good choice! the oil pressure notes here are very interresting, as we all know the life expectancy of any bearing is entirely dependant upon lubrication, temperature, and contaminants. if u have more flow u have more lube, and better cooling. so that in my mind says the frams are sub-par. that is if the pressure statements are factual.
Pressure is read downstream from the filter.I agree about the pressure but isnt one of the things fram advertises about better flow. in my opinion better flow doesnt mean more oil pressure. as long as your within specs it is fine. also if by switching to another filter gives you more pressure then couldnt that also mean that the filter is constricting flow and therfore creating a misleading pressure.
Just by example a 4.0 with a 1.5 inch exhaust is going to be able to shoot a golf ball out of the tailpipe! More pressure. however with a 3 inch exhaust it would probably just flow around the tailpipe. less pressure more flow. i think more info needs to be found out before pointing the finger.
OH BTW i run napa in mine. Done it for years and never had a problem. so I am not a fram empathizer. hehe
Sean
My engine has 202K miles on it, and at hwy speed (2100rpm) has 50psi of pressure per the guage, and when HOT, has 15psi of pressure. I use 10-30W Valvoline dino-oil, and I've had that combo since I bought it at 132K.
I don't see a problem. Not in the slightest. Not even a little one.
My only experience with a fram filter is when I bought the 93 Sport a year ago, the oil pressure gauge was "broken", it was reading off the gauge. I figured it was the oil pressure switch or whatever, but when I did the oil change the gauge worked fine and has ever since. Only real thing I changed was replacing the fram filter, I used the same grade oil as the previous owner said he did. Don't know why an oil filter would cause that, but evidently it did.
We have a 93 Country we bought with 135k on it, it now has a bit over 204k. We use 10-40 in summer, 5-30 in winter. Your post kinda stood out to me since we have a jeep that we've put about the same mileage on.
According to the gauge, oil pressure never drops below the middle/center line, except maybe just a hair once in a while while it's idling and hot. I think that's 40psi? I replaced the oil pressure switch a while back, but I guess I just don't know how much to trust factory gauges in an old vehicle. Regardless, isn't 15psi kind of weak?
