Got some work to do!
new griffin radiator, fan clutch, longer but slimmer trans cooler. Want better air flow for rafiator. Might as well do heater core while I got system all drained. Mainly peace of mind...Basic tune up.
mount new mastercraft baja rs front seats. Front chromo shafts, I know my axle shafts are ready to pop. Have full circle clips on stock shafts, all but 1cap has rotated 90-180 degrees.
wow that escalated quickly! This list has changed - as well as the rig!
Bronze dana 60 kingpin bushings
dana 60 lower king pin covers
mount new 40" tires
swap out tie rod heims (last set of heims to change out)
fix tcase linkage
weld up rear frame/bumper
check toe in
trim fenders
put hockey pucks on top of prothanes
install rear bump stops
check vacuum lines
bleed hydro assist
weld up some plating in the front of the frame to tap to m10x1.5 to mount the pro crack swaybar on the rig and weld some axle side mounts too
Its funny because its true. I dont know if dropping it on my face is more funny than my wife just realizing after a decade that I am an idiot. She must have known, right?
