I have a 2000 XJ with the coil rail -- I recently swapped in a motor from a 98 ZJ with a 7120 head -- No coil rail mounting points -- I wanted to swap over to a viper coil anyway
Drilled the aluminum bracket for the Viper coil -- Had to remove some weld for bolt head clearance -- I don't have a mill but an end mill on a drill press works just fine with aluminum
Test fit all parts on the bracket -- The lower clamp is a weld on hydraulic hose clamp from Surplus Center. It's there to properly route the 2 stainless braided -6an hoses for the transmission cooler -- Being the weld on clamp is steel, and my bracket is aluminum I has to drill and tap the clamp base for 1/4 -20 bolts so I could bolt it onto my bracket
Bought a driveshaft for my rear, installed the 1310 flange, and mated it up to the D44 axle flange. Need to do some highway speed testing for vibes, but it seems pretty good around town.
