DutchVDub
- Milliken, CO
Well the truck is currently at Les Schwab getting a set of Terramax A/T's in 235/85r16 flavor. 120$ a tire with a 40k warranty and the M+S designation. I figure at the price it's worth the risk.
GIT-R-DONE!Well nothing until I get the trailer registered again
I think it's the super duty weight. He said his were E rated.
How many pounds of wire/rod did you use on that thing?:wow:
I was going to say... It's probably safe to say that if that diff breaks, you've got a whole lot more problems than just the diff...
My goal this time is not to do it again. I'm sick of fixing things! I want to drive!
If the axles form a 8000 lb, monster torque, diesel behemoth can't hold up my little Jeep on 38s with maybe 300hp, I need to adjust something in me, not the Jeep.:wow:
(or stop driving Carnage!)
Loctite your inner pinion bearing. 10.5s have an issue with spinning that bearing and eating thru the shim. If yours is chewed up, .028-.032 seems to be the magic number.
I have been test beating my rig on the back roads to see how my homemade drive shafts hold up caught air ...spun tires in 4lo 2lo front and rear....all to redline no kaboom from axles or drive shafts a 5.0 case and 5.13s and 44s is a good test of axle shafts my rear 14 are stock and no kaboom I think a sterling on 38s is like 14 on 38s...lol...not really breakable unless you wedge a tire and have enough torque to twist the shaft when tire stops .
I'm hoping that's the case with the 38s. I'm building for the eventual set of stickies when I wear these out. However, with them being basically new, that will be a long time at the rate I'm going. Maybe the V8 will let me smoke them (I mean heat them up) on obstacles more and take some tread off.
What did you do for drive shafts? How bad was it getting them true? Do you have much vibration? I'm thinking about building my own with the EOR 1410 driveshaft kit they sell. It seems somewhat reasonable at $200 + tube + Ujoints for the kit. There is also a guy from Salt Lake DS shop selling shafts for $275 built and balanced on ebay, but they are thinner wall tube than I'd want. These are of course not CV shafts.
I'm REALLY hoping that what I hear about reusing factory shims is true. Sounds like most people end up being able to reuse them with a good pattern. We'll see if I get that lucky. I am ditching the crush sleeve for a solid spacer. That's another issue I hear about the 10.25/10.5.
