49erRider
- Fort Mill, SC
Tim,
What issues with the swap?
Tim,
Wow, thats quite a bit of smoke... what is it???
Yeah it looks pretty white..... What motor did you use, the trail rig motor or Adams motor?
Didn't do much of anything this weekend.
Started dreaming about just going to a D44 front and rear axle instead of trying to build up the D30. I'm not happy with my D30 for a number of reasons.
The tie rod I pulled from the JY turned out to be bad. Went to put the castle nut on it to tighten it and the whole rod end started spinning.
OK -
So, the TRE going from my new tie rod to the drag link is bad / spins when I try to put a nut on it.
How do I replace this part? I haven't messed with it a whole lot (bigger fish to fry at the moment) but even after scraping the grease & grime off it, I don't see any way to remove the bad end there...
either put pressure on it using a jack or by putting tension on it using a pickle fork.That will keep it from spinning....
BTW.Just because it spins doesn't mean its bad.
