- Southern Maryland
I would like to encourage development of a solid tie rod adjuster sleeve as an HD replacement for the stamped ES2079S adjuster sleeve that is used with the stock XJ/ZJ drag link and tie rod. The stock sleeve is pretty stout, but its just stamped metal. A solid sleeve would be stronger, and should also keep mud and water out of the threads. The ES2079S is definitely the weak link in my XJ drag link and ZJ tie rod, and I would really like something better.
Note that the ES2079S is also used in F-150 steering, so this is not a small little Jeep niche thing
Thank you
Thank you
