Wanted: any 4 door xj door
desertjr
Low Desert
Just 1 currently..if its dented up or scratched up no worries. I was gonna use it to practice cutting on..doing what Eric's xj did for his rockers and wanna practice at least one time before I do it on my axle jeep:eyes:
does it matter if its damaged? I just changed out my drivers door thanks to some moron (hit and ran my jeep) you could have the old one.
I have a complete 88 XJ with no title, no dents, might even run if you wanted to put the time into it. I know its more than you are looking for but......
Newsreel how damaged? Basically it just need to fit semi correctly and I would need to cut around 2" off the bottom. That's the biggest part is if I can cut to the bottom of the door.
I think i have a front door out back.It is from a set off a 4 door.I'll look and let you know.I don't charge for these. Plus i am in sky valley.So the drive isn't to far for you
