Pre-97 Door Glass Rubber
ChillyB
TN
Hello People. New here. Recently bought a 95 XJ and I'm now getting the tingly sensation of impending spending associated with sun-baked side window rubber on all four doors. What do the smart kids do to replace the rotted pieces? Not everything is cracking up. Here's what is ugly. Left and right condition are identical so I'll simplify by describing the pilot side.
1. Front door, bottom outside rubber squeegee.
2. Front door, vertical piece that seals the front edge of the uppy-downy glass
3. Back door, bottom outside rubber squeegee below the uppy-downy glass.
4. Back door, bottom outside rubber squeegee below the fixed quarter glass.
5. Back door, vertical seals on both sides of the vertical black piece that separates the quarter glass from the crank window.
I've found some of the rubber for sale. I don't think I've found all of the rubber. Are some of these pieces no longer available? Before I start buying anything I want to have a solution for everything.
intro niceties: I'm old enough that music industry has long stopped caring about what I like, young enough to still be astonished at how old I've become. This is the third XJ I've owned. I still own this 95 and a 2000. Also have a 1973 CJ5 project close enough to completion that I have few excuses anymore. I live in Middle TN and have a family (so back off, ladies).
Team Cherokee had four door sets last time I looked.
Team Cherokee x2 you will need to order the division bar runner separate (the runner between the fixed glass or vent window both the same).
Thanks. I'll get that stuff ordered up. But I suppose next money is floor pan(s). Pulled carpet to hose out a decade of Wendy's Frosties and cigarette ash. Nothing going back in until floors are fixed.
I just did this job on one of my rear passenger doors of my '87. Here are some part numbers that may help:
1984-1996 Front Door Division Bar Glass Run – 55002337
1984-1996 Rear Door Division Bar Glass Run – 55005666
1984-1996 Front Door Glass Wipe (Outer Belt Seal) – 55135206
1984-1996 Rear Door Glass Wipe (long) (Weatherstrip, Outer Belt) – 55235404
1984-1996 Rear Door Glass Wipe (short) (Outer Belt Seal) – 55005377
On the back door the bar glass divider between operable and fixed glass, the glass runs are different for the operable (front facing) and fixed (rear facing). I don't have the factory part number for the fixed glass side, but I found it at a website called RubbertheRightWay. Part #10-372X. RRW also has the front door divider glass run, part #10-363X. I got my outer glass wipes from Quadratec.
One note when taking apart the REAR door to swap this all out, there is a rivet holding the rear door division bar glass run on the outside under the lower trim piece. Took me a while to figure out why I couldn't get that divider out. There is an obvious screw at the top, and a bolt on the inside accessed after removing the door panel, but the rivet is hidden under the outside trim.
I recently ordered a whole door kit on summit from precision, all worked and fit fine, pricing seemed better the the team site, but if they are a sponsor I would go there
I ordered entire set from Team. Increased my Jeeps net worth by 20%. But I'm fixing floor rust and converting to 4WD so this is a long-term commitment. Do it once, do it right, then do it again, then again.
