lawsoncl said:
If it's acting more like a battery, which adding an acid or strong base would imply, then v=i/r won't be linear. You won't see any current flow until you exceed the voltage potential of the battery, after which you'll see a somewhat linear slope of the voltage/amperage curve. There may be a voltage breakdown threshold as well - sort of like once you draw an arc in air the resistance drops dramatically.
Still, I think 15 amps at 12 volts seems very high. Thats 180 watts and if my rough back of the napkin is right, once you hit boiling temp thats almost 5 cc of water boiled off per minute. That's much more water loss than these guys are reporting.
The breakdown voltage gets involved when the water starts splitting, I think, and the apparent resistance drops at that point. Then it levels back out and evently goes flat as the gas bubble population reachs a peak and masks the electrode surface. There will be linear, and nonlinear parts as the voltage is increased, and as the water heats up.
So, you going to make me do some math!:scared:
1 KW= 239.006 Cal/sec
180 Watts is 0.18 KW
so we have 0.18 * 239.006 = 43 Cal/sec
It takes 539.79 Cal/g to convert one gram of water liquid to vapor at 100 C.
At 43 Cal/sec we get 43/539.79 = 0.0797 g/sec, and I get 0.0797 grams per second converted to gas, assuming perfect insulation.
IIRC 1 gram of water at STP is 1 cc of water.
so in 1 hour of driving, 12 volts, 15 amps, we have:
60min*60sec=3600 sec
3600 sec* 0.0797 g/sec = 286.92 grams of water turned to vapor in 60 minutes. 286.92 grams is also 286.92 ml, or 0.286 liters of water.
3.8 liters per gallon, and so on.
4.872 grams per minute is what I get, so your 5 grams per minute is pretty close for a napkin calc, LOL!:cheers:
So if they are pumping 15 amps into one of the bigger units, they can't be boiling too much water at the rate of consumption they are reporting, so a large portion of it, if it is pulling 15 amps, must be going to splitting the water into hydrogen and oxygen, which I am told is energy intensive. Time to calculate the heat of formation of water next.
Of course, we are still waiting for a real amps reading from someone on their generator.
lawsoncl said:
The thermodynamics laws say 10-1+1 < 10.
Can I quote you on that?
LOL!
