Ray H
- Falling Waters, WV
white_elephant said:aussie front
what is that???
is it a full time lock in the front? they told me you cant drive in 2wd if you have the front lock all the time...is this true??
Not true,
Automatic lockers are locked by torque being applied to them. If theres no torque applied, they do not lock. If you are in 2WD, there is no torque going to the front differential so the locker is basically invisable.
There is a such thing as a "spool" thats what I consider a"fulltime lock". A spool is basically a solid piece of steel that spans the gap between the axle shafts so they are mechanically conected together at all times. You dont want one of those in the front at all unless you race in straight line mud bogs, cause thats about all theyre good for.
