CheapJerokee
- CA
So, under the advice of Anak, I ordered a new water pump, coolant, radiator hoses, radiator cap, coolant temperature sensor, and a new thermostat. The thermostat housing looks really new so I am not replacing that.
I will also be replacing the fan clutch and belt.
Today, on a whim, I decided to put in the new radiator cap, coolant temperature sensor and vapor solenoid thingamabob. As I was about to start wrenching on the coolant temperature sensor I went to unplug it and the plug just came off. The clips were completely broken off. The gauge works just fine (or it's doing a helluva job fooling me). I've read that on the 97 and newer XJ's that there is only one sensor and that sensor sends signals to the ECU and to the gauges. Furthermore, the sensor could be bad but still functioning well enough to have the gauge working but not functioning well enough to tell the ECU how much fuel to send. Does that sound like that is happening here?
After installing everything, I went to the gas station and put a little over 5 gallons in. I then drove over 40 miles. The gas gauge moved but not nearly as much as expected. I wonder if this was the reason why it was running so rich resulting in my 10mpg.
