bcmaxx
- The West Kootenays,B.C. Canada
yourconfusedhaha said:im not going to lift it to keep the cog low
the problem i've noticed with the jeeps in tuff trucks is the rear slip yoke slides out in the woops and just leaves ya sittin there for the tow truck to come
im thinking if i took the stock slip yoke, drilled a hole in the yoke and out put shaft and tapped the output shaft it would act as a sye then i can just make a square tubing drive shaft and not have to worry about it falling out
almost, but its gotta have In-Out slip somehwere! either on the yoke or the shaft
