Burchie
- Corona, CA
Leaking at the fitting. What's the best option here?
:cheers:
:cheers:
you can't replace just the fitting, it's crimped onto the hose. A new hose assembly would come ready to put on with the crimp fittings on both ends. you could cut the crimp fitting off and then get a fitting to go into trans or cooler, but your hose is going to end up too short.What part are we talking about getting new? The whole line from the tranny, to the cooler, or just a new fitting?
^^ looks great, hope you flared the ends of those metal lines lightly though, else you're just waiting for some bad luck before the rubber line pops off.
I used new OEM style lines from Dorman because I like the way they are preformed to stay out of the way, but if they rust out again I'm probably doing the same thing you did.
