To-Do List
laundry (to make MrSimon happy)
need to pack spare parts
need to buy and pack food
need to make new rear driveshaft still... have all the materials now. I could make it without this but I want a smooth ride on the way down.
clean yard up enough that the building inspector will be pleased if he drops by again
I think that's about it? My e-brake cable even works now. I'm not really sure what to think about this.
manage to finish this day of work
pack
go food/poptart shopping
booze run
hit up ATM
hook up trailer to truck
fill up both truck and jeep
touch myself
rear bumps maybe
put legit brake caliper spacer thing on and take out the shim i made
trim gas tank skid
Put in washer bottle from renix parts jeep
wash it, clean the inside, pack it up
Some spares packed
driveshaft made and tested
yard close enough
Need to finish laundry, pack and buy food, and fling all my tools in the back.
throw the doors on for the ride down
load on trailer
pack the cooler
not bad considering this time last year I was still making a mad attempt at finishing the fullwidth swap that I started 4 days before nacfest
Install rear locker DONE...now have to take it back out since it's not working correctly....:thumbdn: DONE (Again...)
Redo Brake Lines DONE
Install LCAs DONE
Cut Fenders, Cut+Fold rear quarter panels DONE
Install Flares DONE
Pick up new(ish) tires DONE
Install new trackbar DONE
Install new springs DONE
Install TC skid plate DONE
Install new shocks DONE
Install Disconnects for swaybar DONE
slather copious amounts of di-electric grease around my engine bay PURCHASED
redneck alternator splash shield Maybe...
seal up rear quarters and bondo SEALED AND POP RIVITED
bondo up fender folds prob not gonna happen...
Repaint front plastic and front/rear bumpers
Get spare tire mounted and balanced DONE
Install LCA skids DONE
Mount Fire Extinguisher and First Aid Kit
Wash it
I forgot to put my crossmember I built on, hope I don't break the stock one in half
Weld in tie down points in bed
Spare tire mount
Add a couple strips of angle to better mount my crossmember
Vacuum interior,clean the glass, pack up.
as of right now this is all i gotta do.
i worked on it from 5 til now today and im goin home.
Install LCAs DONE
Install Flares DONE
slather copious amounts of di-electric grease around my engine bay TONIGHT
bondo up fender folds not gonna happen...
Repaint front plastic and front/rear bumpers DONE
Mount Fire Extinguisher and First Aid Kit DONE
Install thumb throttle TONIGHT
Wash it If time allows...
I got a spare, want it?
If you feel like I. I've passed up 3-4 in harrys u pull so far today. God its hot out.
