To-Do List
Install rear locker DONE
Redo Brake Lines DONE
Install LCAs DONE
Cut Fenders, Cut+Fold rear quarter panels DONE
Install Flares
Pick up new(ish) tires DONE
Install new trackbar DONE
Install new springs DONE
Install TC skid plate Partially done (damn you skidrow...)
Install new shocks DONE
Install Disconnects for swaybar DONE
slather copious amounts of di-electric grease around my engine bay
redneck alternator splash shield
+ seal up rear quarters and bondo
all i got is install fan shroud and ps cooler tomorow, then its just gas it up and load it on the trailer
60 list:
gear 60
Limit straps?
14b:
finish driver side hub
plumb brakes
fill with oil
driveshafts
finish Atlas support Xmember
mount Iroks
re-run exhaust
some trimming?
-Cut out floor and build subframe and skin it, relocate stock AW4 shifter - DONE
-Finish front half doors and trimmed for rockers - DONE
-Build rear shock hoops, tie them together and to other stuff, mount shocks - DONE
-Build rear bumpstop pads and mount poly bumps - DONE
-Finish painting the jeep with a brush - DONE
-Make rocker and belly skids, 1/8" plate + 1/2" plastic - Half done
-Some sort of seatbelts, probably just gunna run stock ones for now - DONE
-PSC hydro assist setup - DONE
-Tiddy up brake plumbing and rebleed -Still gotta rebleed
-Muffler heatshield/gas tank housing sheetmetal - DONE
-Maybe some shorter shackles - Removed some leafs instead
-Play with the StaK - DONE
-Regrease/hit the instrument panel so my gauges will stay working again - DONE
-Shakedown run and some thorough testing - So far so good
-Try not to flop it, I'll wait til NACfest for that - So far so good
-Acquire new tow rig possibly
New stuff added:
-Hoop/skid for assist ram
-Weld rock rings to the rims and install Inner Air locks
-Get a RADesigns shifter/controller
-Get soft tops for the doors made
-Steering wheel cover
-Build a toolbox and spare fluid rack
-Buy a cheapo Craftsman tool set as trail tools
Jeep is ready to go, probably going to build spare driveshafts.
Gas tank on the tow rig started leaking today, have to replace that
good to go, replaced the radiator last week just need to get all my spare parts etc ready
spare parts about ready, front shafts, rear shaft, tie rod & driveshaft, every fluid
- DONE Bend up harness bar and X brace for cage, finish weld and paint it (hopefully this weekend)
- DONE- Finish building 440
- DONE (surprisingly wasn't that bad haha) Get 440 to fit in engine bay :laugh:
- DONE - Build motor mounts
- DONE - Modify/ build crossmember, transmission mount, NP205 rear mount
- DONE - Redo traction bar crossmember mount (move to passenger side)
- DONE - Build new driveshafts
- DONE - Mount radiator, plumb cooling
- DONE - Build exhaust
- DONE - Center console and transmission tunnel
- DONE - Slave cylinder mounting/routing
- DONE - New dash and gauges
- DONE - Seal up/paint NP241/NP205/NV4500
- Build floors
- Build wiring harness
Carburetor is staying on for NACfest. Going to build the wiring harness this coming week/weekend, and do as much floor work as I can.
New list:
Stiffeners - DONE
Sliders - DONE
Build HP30 - ARB/1 ton OTK - Not happening...
Fix winch
Fix E-brake
Swap OEM fan back in - Done
Swap in Durango box
Rebuild front shaft - Done
Hook up tcase linkage - Done
Put interior back together
I need to GSD....
New stuff added:
-Hoop/skid for assist ram - DONE
-Weld rock rings to the rims and install Inner Air locks - Supposed to be here tomorrow
-Get winch working - DONE
now that im getting close. i can be more specific as to what i have to do.
front pinion seal
t-case output seal
traction bar (just the bar, mounts and crossmember are done)
mount front airbumps
mount rear poly bumps
mount rear shocks and shock hoops
weld in sheet metal for bed floor
swap durango steering box from xj to j10
new power steering hoses
fuel injection stuff:
mount fuel cell.
plumb fuel system
wire up fuel pump
bolt all the tbi shit to my motor
plus a bunch of wires to the new stuff on my motor
put 12 volts to the big wire on my new wiring harness
put 12 volts switched to the little wire on my new wiring harness
i think thats about it.
hopefully i get a day where i can go over the truck, check over every fastener, check all fluids, and paint some of the bare metal.
Install rear locker DONE...now have to take it back out since it's not working correctly....(n)
Install LCAs DONE
Install Flares DONE
Install TC skid plate DONE
seal up rear quarters and bondo prob not gonna happen...
bondo up fender folds not gonna happen...
Repaint front plastic and front/rear bumpers
Install LCA skids Maybe...
Hmmmm
Get spare axleshafts+housing
make spare rear driveshaft
hackpatch frame
Pack beer food and hammock
I think that's about it
front pinion seal
t-case output seal
swap durango steering box from xj to j10 DONE
new power steering hoses DONE
pretty much decided im not doing the fuel injection stuff.
front pinion seal
t-case output seal
forgot rear bumper, and put offroady stuff in my carburetor
install front d44 - nope
install 8.8 - nope
some how make 37s fit - nope
beef up steering - nope
get tow rig - Done
get trailer - done
register- done
all i need to do this weekend is pack, get the 34's back on there, buy an mp3 player for the truck, clean and air out the jeep, then get the jeep on the trailer so i dont have to do that Tuesday night or Wednesday morning
fixed my tcase linkage by hammering the body side up to match the drivetrain's height. should be good enough. works fine now. and i welded the door busted door pins on, and have a spare just in case. i'm ready to go.
