ktm racer 419
- ROW DIALIN
hula girl should not be optional
i have the hula girl acquired. i just need to mount her
giggity
Install rear locker DONE
Redo Brake Lines DONE
Install LCAs DONE
Cut Fenders, Cut+Fold rear quarter panels DONE
Install Flares
Pick up new(ish) tires DONE
Install new trackbar DONE
Install new springs DONE
Install TC skid plate Partially done (damn you skidrow...)
Install new shocks DONE
Install Disconnects for swaybar DONE
slather copious amounts of di-electric grease around my engine bay
redneck alternator splash shield
60 list:
gear 60
Limit straps?
14b:
finish driver side hub
plumb brakes
fill with oil
driveshafts NEW U-Joints DONE
finish Atlas support Xmember DONE
mount Iroks
re-run exhaust
some trimming?
New list:
Stiffeners - DONE
Sliders - DONE
Build HP30 - ARB/1 ton OTK - Not happening...
Fix winch
Fix E-brake
Swap OEM fan back in - Done
Swap in Durango box
Rebuild front shaft - Done
Hook up tcase linkage - Done
Put interior back together
front pinion seal
t-case output seal
traction bar (just the bar, mounts and crossmember are done)
mount front airbumps
mount rear poly bumps
mount rear shocks and shock hoops
weld in sheet metal for bed floor
swap durango steering box from xj to j10 DONE
new power steering hoses DONE
pretty much decided im not doing the fuel injection stuff.
install front d44 - nope
install 8.8 - nope
some how make 37s fit - nope
beef up steering - nope
get tow rig - Done
get trailer - done
register- done
