To Do List
The swamp ass meter was at its most highest levels here over the weekend. I was working out in front of my house & had to take numerous breaks, so I did not turn into liquid. Jeep is just about ready, just need to change the oil & re-check everything next weekend.
Thanks for reminding me... gotta do that "change Oil" thing too...
Not gonna get my traction bar done before NAC-Fest, just no time right now. The shackle re-location brackets are modded and will be welded in place though.
A.
Hmm...
- reinstall & bleed rear brakes
- rear diff cover/new bolts/sealant/torque axle bolts
- longer upper links
- service rear driveshaft
- service front driveshaft
- redo coolant reservoir
- wire horn
- re-fit gas tank cover
- order/install limit straps
- reinstall window nets
- service steering as needed
That's for the Line Mountain race this weekend. :)
I'm sure I'll have a new list to take care of next week though. :(
Hmm...
- wire horn
Nice, looks really good Chris!!! Did you add all of that additional structure/tubework to the rear too?
Yeah, rear axle was a complete re-do.
The shocks are ridiculously big.
Still have some clearance issues to work out, probably not before NACfest though.
A.
Yeah I change the oil in the jeep based on what the dipstick looks like because I dont drive it enough to know when its really time to change it.
To Do:
transmission fluid and filter
Done (or not going to get done)
Axle seals in the 8.8 (stupid centering pin bolt broke for the second time with this axle so NOPE!)
Wire winch NOPE!
Water pump (preventative maintenance if there's time) NOPE!
Install new long side D30 shaft DONE!
Front bumpstops DONE!
XJ
- weld in stock gas skid
- JB weld fuel pump return line nipple to face plate
- grind out spare shafts for full circle snap rings and put in some fresh x760s
- double check all fluids
- maybe clean it?
CTD
- bolt in 98-99 HD style steering NOT HAPPENING
- oil change/rotate tires DONE
- possibly rolling/locking tonneau cover? NOT HAPPENING
Also new fuel filter, air filter, etc. Just maintenance.
Gonna knock out the XJ stuff on Saturday/Sunday.
-spare set of shafts with full circle 760's READY
-spare set of WJ ball joints READY
-spare RHD WJ draglink TRE READY
-spare 00+ hubs from jeff :kissyou: READY
-spare D30 yoke/straps READY
-spare 1310 u joint and spare 297/760 parts READY
-spare claw READY
-oil change in the duramax DONE
tomorrows goals:
-spare other three WJ TRE's (gunna get some free lifetime replacements :greensmok)
-grease/check bearings on the trailer, adjust brakes if needed, check tire pressure
- reinstall & bleed rear brakes DONE
- rear diff cover/new bolts/sealant/torque axle bolts DONE
- longer upper links NOT GETTING DONE
- service rear driveshaft DONE
- redo coolant reservoir NOT GETTING DONE
- wire horn DONE
- order/install limit straps ORDERED
- reinstall window nets HALFWAY THERE
The rear coilovers feel fantastic. :D
Time for another update...
1. Fix bulkhead connector on firewall so truck always runs DONE
2. Install HD tie rod Plan is to do this Fri. AM
2. Paint/Install JCR TCase Skid Nearly done - just have to put in the last bolt and tighten it all down
3. Install lift parts (to get from 2" to about 3") Doesn't look like this will get done, just don't have the tools or time to deal with the bushing sleeves/upper rear shackle bolts frozen together
4. Source/install new power antenna DONE
5. Fix power mirror wiring
6. Readjust deflators from 12psi up to 18psi
7. Swap in new headliner/Keyless entry retrofit/new front door seals DONE, DONE, and DONE
8. Repaint/install replacement OEM rear bumper (deferred - will run the bent one for NACFest, save the nicer one for after)
9. Fix horns
10. Fix CB radio antenna DONE
11. Mount cupholder Will do Friday
12. Install ZJ Shift Knob DONE
13. Fix loose switches on LF door DONE
Setup bump stops
Raise rear shock mounts
Install trans cooler
Intall BDS tc skid
Rebuild upper control arm flex joints
Replace steering box
Re-wire CB and lights
Go buy a fire extinguisher and first aid kit.
Wire up CB
Install adjustable UCA's
Change oil
That's it except for packing up and buying some supplies
new to do list
-install front end- DONE
-get u bolts made for d44, install - UBOLTS MADE
-install rock rails - PAINTED
-get someone to make me some unibody tie ins for my rear bumper -COME ON, ANY TAKERS? (any takers) :D
-change oil/tranny fluid
-diagnose/fix TCC code - CODE WENT AWAY
Since everyone else is posting up there final list ....
1. Change oil - bought stuff, just need time
2. Take the car seat, baby dolls, hair ribbons, and the diaper bag out of the truck
3. Go to the Cigar store
4. Pack camping supplies
5. Charge up camera batteries so I can take awesome pics of all you crazy stoopid guys rolling your Jeeps on the new property !!!!!!!
Are the jokes about pushing your jeep and the flat bed played out now? I think everyone may have unjinxed you...... but probably not.
hey mr. simon dont forget the butane so you can reseat your bead this time when i am towing you out lol......:laugh3:
I am glad to hear you have the MJ in good running order I hope you get to run all day this time.
Originally Posted by rweaver138
new to do list
-change oil/tranny fluid -TRANNY FLUID DONE
ADD:
-install t-case skid
-remove flowmaster cat back off old jeep, install on new
-install gas tank skid
