bosco01xj
- Lebanon, TN
In order to keep proper pre-load on the uni-bearings you must have the stub shaft installed and torqued to 175ftlbs or the uni-bearing will fall apart. Carry at least one, better yet 2 stub shafts/unibearings. Another killer for the D-30 is the axle u-joints and stock shafts, if a axle u-joint lets go it will take out the stub shaft ears and can take out the ball joints and also bend the inner "C". That is why most who wheel hard on a 30 will run chromo shafts and stronger joints or go with Longfields like I have.
Of course strengthening the shafts puts the load on the carrier/R&P so if that breaks you will need 2 stub shafts and axle tube plugs to get back home(just remove front DS, both axle shafts, install stub shafts and plug the tubes and drive home in 2wd)
He was running a chromo shafts.
