I used 3' of 1.5" OD .25" wall DOM with 3/4" x 16 tube inserts for the tie rod and Dodge tie rod ends ES2847R ES2848R. For parts store searching purposes use 1991 Dodge Ramcharger. Total amounted to around $100 even for the rod ends and all the hardware (jam nuts etc.) which I feel is worth it. The Dodge tie rod end is slightly larger than stock (3/4" vs. 11/16") and has the same taper as Jeep.
