Not to bust your chops but the correct way is to put a block the thickness of the spring pack between the axle and the main leaf. That way the axle is spaced down correctly to check/verify when the bump hits the axle.
no real progress. Work has been killing my time off.... working on getting the interior enclosed again. I keep changing my mind on how to do it. I decided to add some more cross bracing and gusseting, so I lost some progress I did have.
I did get some of the front section done and some gussets done....
my welding is getting better... so I'm gonna show this pic off... I won't show any other welds because they suck. :roflmao:
also been working on how I am going to tie this in to become a full cage. but that will come later.
Update: progress has been slow, but it is coming together. should be a functional vehicle by socalfest. certainly won't be finished, but at least driveable.
got the shock towers in and everything mounted up. just a little bit more sheet metal work on the inside and the outer plates to be welded on.
I ordered a set of springs from National Spring, but the jeep needs to be weighed before they can be made so I will be running the REs until they are done.
back on its own weight: once the nationals go in it will sit about 2" lower and the tire will be about 4" further back.
