hawkeye 1
- Redondo Beach, CA
plating and a cage should allow one to cut off whatever they want .
Agreed, if you do it before cutting the body.
hey hey don't drag me into this mess, lol.
then how do you get people to help you in the first place!? lol.
This only works if you weld braces into the back before cutting. I hope you did that before opening the tailgate.
The body will keep on cracking along those sharply cut corners, even after you plate it.
Ask Grimmy for some pictures of cracks in his Jeeps body, before he started cutting panels away.
Missed this post...
Not worried about it. This thing will not move until all of the structure has been added back/increased.
And the hatch was open before we started... Still closes fine
You missed my point completely Taylor. To make your rig into anything worth while, you should have measured it square and welded in some braces before cutting it up.
Anybody can weld crooked sheet metal together and make it look ok .
Geometry is the most important factor in anything you're trying to build if you want it to perform flawlessly.
Just ask some of our members here who are into real racing, they will tell you how important it is.
Shut up and build your own jeep.
someone here races nascar?
He said real racing. That involves right and left turns.
do yourself a favor, pull the gas tank before you weld that strip to the floor. don't melt slag holes in your filler neck hose like I did :shocked:
