- Hammertown, USA
field testes?
CartsXJ said:ok I see now. I have a question could you have just unlocked both sides and shifted to 2wd to get home? Or was the deformation so bad it effected the bearings?
cracker said:Too bad it hasn't been field tested![]()
vintagespeed said:As usual, I agree. The "ultimate front axle" changes with the ebb & flow of your favorite group of wheelers. This idea is influenced as much by imagination as geographic location.
vintagespeed said:Custom does take time, as does good work. :laugh3:
vintagespeed said:...take time, as does good work.
cracker said:With that logic, Sintax's rig should be the perfect rig, if it ever gets done :laugh:
GSequoia said:So your rig should be done in a couple days.
:illegalflipoffsmilie:
vintagespeed said:It's called "priorities" mang, some of us have more to deal with in life than just being the "most improved" web wheeler on Naxja.![]()
Mr.OverKill said:for all around use ( West coast dunes and rocks ) for the money that is???
is it the venerable HP D60 ( king pin or otherwise )
or the HP D44 ( strength is not always the first priority )
the HP D30 ( we have it, it works )
the latest wave of custom 609's ( alot of money for what gains?? )
the 44/9 setups ( dont really know much on them )
the 44/60 combos
or the bad talked but in expensive HP D50 from the F250
or the newer dodge LP D60 ( easy and cheap to find )
how about the rare and massively strong Corp 14 bolt front axle?
what about a totally custom housing of my own design with D60 outers
or a 14 bolt with 60 outers ?? you get the picture......
throwing these Q's out before i start throwing money to the four winds, those of you that know me know i will save on fab work since i do all of my own and dont need to buy brackets or pay for re-tubeing ect...
let the debate begin
P.S. i live to build the ultimate axle that will be Budget Built and Bullet Proof and i want your honest opinions, not what billy said if you get my meaning, your thoughts and reasoning.
Thanks
send it to me, i can use it. but first what do you want for it??goodburbon said:I hope the 44 isn't a bad route to go, I'm about to put one in, I'm tired of the 30 breakin on 33's.
I can't justify re-gearing the 30
gears and install kit $200
Installation ...........$300
New Unit Bearings ..$200
Truss ...................$150
grand total $800
Versus a D44
Axle.....................200
Gears and kit.........200
Truss/bracet kit.....350
Brakes...................90
mini spool...............60
tubes...................100
hubs....................200
Axles....................300
install...................200 (gear guy charges less if you bring bare axle)
Bearings.................30
ball joints..............100
grand total...........1830
Oh holy crap I hadn't added it all up before, i don't have an extra 1000 dollars.
Damnit to hell I am tired of this crappy 30 and it looks like I'm stuck with it.
Anyone want a HP d-44 de-tubed diff?
vetteboy said:I think I missed what size tire you were running?
About every other trip I see a guy with a knuckle hanging off a D44 because the balljoints let go after a sidehill stop with 38s or so. Kinda makes me laugh now. Then there's the guy I helped fix a few months ago who broke a spindle off his 44...running 38" SXs I think.
With the amount of money you just described, having stupid un-upgradeable things break like I just mentioned has got to be a pain in the ass. Really makes me wonder why you wouldn't just go with a 60 the first time around, and lose all the weak links of a D44 in the process with stock hardware and easy-to-find parts.
vetteboy said:It's a bitch, ain't it?
I was on 33s forever and then I started going down some new stuff with guys in the 37-40 range, and it just went downhill from there when I found a local deal on my 39.5s w/beadlock wheels.
I have a little philosophy when it comes to this stuff:
Cheap, big, reliable. Pick two.
It's an expensive game with absolutely no monetary return on your investment any way you look at it. I've stopped keeping receipts, I've given up trying to figure out how much I have in this stupid thing. I don't even know why I get such a pleasure out of running the trails and terrain that I'm going for. All I know is I'm building this vehicle to be able to do what I want to do, and if a gigantic D60 is what it takes, well, I guess I've got that covered at least.![]()
xDUMPTRUCKx said:i ruined the begining stages off wheeling for myself by reading too much naxja.
i didnt touch a trail till i had 36s and was locked front and rear.....the only thing i ever broke on the 30 was a ring and pinion and it was my fault cause i didnt install something right.....
Goatman said:Everybody should wheel stock, that's how we learn to drive and pick lines..........and it's too much fun seeing where you can take your stock rig.
I've had fun on every trail I've run, no matter what stage of build up my rig was on. Building them bigger is more about keeping up with your friends than it is about having fun.
88rockxj said:question for the d44 guys breaking hubs
8 lug or 5 ? i herd the 5 lug external locking hubs flex more then the 8 lug which is inside the rotor causing more breakage?
