5spd_xj
<<the good ol days
- Dracut, MA
ok thats fine too. Save my trailer fenders some carnage :laugh:
i wourld seriously consider it on travis's rollersXXXX you! he's getting temp plates and driving this over
You can have the rollers, but one has a slow leak and ones got a gash/plug in the sidewall. If you have 2 good ones youll be in good shape :thumbup:
If not, the 4 of them would probably be fine, though i wouldnt count on the one with the leak to hold air enough to drive over then home again. Worst case you call for a rescue mission![]()
Ahhh wheres my motor!
there it is
next week it will get lots o goodies
rear main
oil pan gasket
valve cover gasket
spark plugs
cap
rotor
waterpump
t-stat
intake/exhaust gaskets
injector orings
Brown Dog block brackets and poly mounts
full cleaning of all the mud n oil
Cummins Biege paint
new flywheel and clutch
then mate ax15 to it for final time
also gonna clean all the dirt and leaves from the engine compartment, patch the rust spot under the batt tray and paint the engine compartment gloss black
rear main
oil pan gasket
valve cover gasket
spark plugs
cap
rotor
waterpump
t-stat
garrett t3/t4 turbo
injector orings
Cummins Biege paint
FIFY
Should have painted it green...to match the motor stand
