The Stupidist Jeep on the Planet
ok thats fine too. Save my trailer fenders some carnage :laugh:
You can have the rollers, but one has a slow leak and ones got a gash/plug in the sidewall. If you have 2 good ones youll be in good shape :thumbup:
If not, the 4 of them would probably be fine, though i wouldnt count on the one with the leak to hold air enough to drive over then home again. Worst case you call for a rescue mission :)
i already got 2 good rollers from ryan, they even have decent tread, he kept the crappy one
motor is ready to come out, gonna get a engine hoist tomorow then pull it after work
Ahhh wheres my motor!
there it is
next week it will get lots o goodies
rear main
oil pan gasket
valve cover gasket
spark plugs
cap
rotor
waterpump
t-stat
intake/exhaust gaskets
injector orings
Brown Dog block brackets and poly mounts
full cleaning of all the mud n oil
Cummins Biege paint
new flywheel and clutch
then mate ax15 to it for final time
also gonna clean all the dirt and leaves from the engine compartment, patch the rust spot under the batt tray and paint the engine compartment gloss black
Gay
there it is
rear main
oil pan gasket
valve cover gasket
spark plugs
cap
rotor
waterpump
t-stat
injector orings
Cummins Biege paint
rear main
oil pan gasket
valve cover gasket
spark plugs
cap
rotor
waterpump
t-stat
garrett t3/t4 turbo
injector orings
Cummins Biege paint
FIFY
managed to clean up the engine compartment a bit tonight
hopin to have it painted by the weekend, dont expect much to hapen next week as ill be stupid busy at work
got a late start this morning as it was a late night last night, got the motor on a stand, pulled lost of the stuff off it and tossed some paint on it, came out ok, oil pan will get painted seperatly and ill be putting a late model stamped steel cover on it, both will be matching Cummins Beige, all assc. brackets will be gloss black
wont have anything done till next weekend as im workin stupid hours at work this week
motor gots some color now
gonna try and knock out more stuff after work tomorow and during the week, id like to have it back into the jeep late next week pending the arrival of some flywheel bolts
got ac comp and alt back on, tomorow shall consist of cleaning intake and giving that some paint, then its just rear main and op gasket
valve cover is on for final time, also picked up blingin chrome breather to replave broken one
also did rear main seal, oil pan is curently oil pan is off reciving paint, i may be spending a wee bit to much time on a motor that i dont expect to last longer then a year, for now i leave you with a pic of a yucky rotating assembly
