- Torrance, CA
i dont know about that, i've put a few 7.5's through the wringer.
Can't fit a 9", eh?
wonder what it runs in the quarter. high 14's? lolsounds like a fun ride
http://losangeles.craigslist.org/wst/cto/2864076942.html
i'm not really knocking it, i was just kidding around... but realistically, what do you think it's actually going to run? maybe 12's?Are you thinking it's not fast because it has a 6 cylindar motor?
Better think again! Every part added and mod done to that thing has increased it's speed and added horsepower.
Thanks for posting Grimm! Coming from a racing background I enjoyed seeing this and can appreciate how much money and time he has into it.
I doesn't the Filarski Bros XJ put out around 300hp without a stroker? then you figure in that a stripped out 2 door can probably get down to about 2300 pounds or so, and it should be pretty quick. Stock XJs can come in as low as 2800 pounds.i'm not really knocking it, i was just kidding around... but realistically, what do you think it's actually going to run? maybe 12's?
cant imagine it has much more than 300hp without NOS.
There are 6 cylindar engines out there that with a supercharger push 700+ hp and will run the qtr in mid to high 9's at 140mph! But you're talking big bucks!
syclone.I need to do this to my 4.3l Vortec!
i saw it was set up for NOS, but i dont really count that, it's cheating lolVanimal,
I think you're in the ballpark at low to mid 12's only because it's normally aspirated on a smallish carb with vacuum secondaries. He says it's setup for NOS in his ad so squeezing that bottle on a stage II system is going to get him down to the finish a WHOLE LOT FASTER!
Looks like he's running cheater slicks and has white striped them so probably using VHT to hook off the line. The tranny & 3rd member are rock solid so transferring that power will be no problem. There are things that need to be done to make it a little more sano like a break-away steering column, cage mods, fuel cell, and rear mounted shut-off switch etc. but it's almost there.
