Mnkyboy
- Sandy,Oregon
7" is what I'm shooting for as well, I had planned to come up through the drivers floor but I may have to go through the passenger side like you did.
The angle is from center of joint to center of joint, the pivot points. So on the TRE's the angle will be through the ball-and-socket-thing, which is basically in line with the tube. Don't measure from the taper (pitman arm), or the bolt/nut. It's easier to visualize on hiems since the bolt literally goes through the center of the joint.On the last pic
Where do you measure angle? Middle of TRE or flat surface of the Pitman arm?
Always get confused with that
Thanks, Ken. It's good to see you post up. It would be fun to catch up, let me know if you guys venture out this winter.You do nice work Dustin.
Winch bumper is off for good. Won't fit over the frame with the front end plating, and I'm not motivated to try and make it work. It'll be for sale soon. A new winch bumper is on the winter agenda, but likely won't happen before Thanksgiving.Bumper going back on?
or is Version2.0 on paper?
It's been tough having the Jeep down this long, but it's all slowly coming together. I thought about tossing a tire on, but it's kind of a pain to cycle with a floor jack and one person. I know I'll likely have some sheet metal interference under the fenders, but I'll cross that bridge when I come to it. What's a little more cutting. :dunno:I was surprised to see you checking things W/O the tires on. I take it you plan on taking car of tire clearance issues after its all said and done? Its looking good, the quality and haste of the build makes me think all of your research and thinking is paying off.
Looks great man. you will be back out there in no time flat.
Bronze.
Got a lot of welding ahead of me in the next few days, but we're on the home stretch now.
Thanks, man. I use to not enjoy fab work, and only made my own parts because I was cheap. While I still am cheap, I now find myself thoroughly enjoying the work. I look forward to the time I can nerd out on the Jeep in the garage.You do some amazingly nice work! This is the nicest late model build I've seen in a while, and your knocking it out pretty quickly too! Nice work
