NW99XJ
- Gresham, Or.
Do you feel a little better now that you have some armor on it?
Looks good BTW....
Looks good BTW....
That thought did cross my mind. The problem with the mount is that it has an inside dimension of 7.75", and the cylinder has a diameter of 8". So the cylinder doesn't exactly fit flush in the mount.Dustin, I run the same mount, all I did is went to a hardware store and picked up a threaded coupler and bolt to lengthen the arm to fit around the tank, works great and only cost a couple bucks
Summit Racing, $85.Can I ask where from, and for how much you spent on your fluid coolers project?
I actually started this to let others know what not to do. I just haven't had any big f*ck ups yet.I love this build, Half of it I've already done, the other half is great idea's and info!
The temporary part I mentioned is the OEM spare tire mount I modified. I'll be keeping the actual aftermarket cylinder bracket. That will get hard mounted to whatever I decide to do with the cargo area.When you're done with that mount.. I'd love to buy it off you! (if that's what you were insinuating)
Ordered the bracket online.
Wares DirectWhere did you get the bracket?
