-Shock mounts - This weekend, do them.
-Plate front crossmember under winch - Skip if you have to, Chris and I are fine.
-Set rear axle at ride height, tack on perches - This weekend, do them.
-Build spring pack/shackle location - This weekend, do them.
-t-case skid (1.75x.120 DOM 180* bend, 1/4" plate tabs, 1/4" plate bolted to tabs) - We can do this when you come up to gear the axles.
-Drill out leaf spring center pins to 7/16 and use socket cap bolts - This weekend, do them.
-Patch floor rust - This weekend, do them.
-Cover floor over UCA - This weekend, do them.
-Hydroboost - Stop crying, you have the parts like.
-Build PS reservoir mount - Took me 15min.
-Build fuel cell mount - This next week, do this.
-Relocate battery to bed - This next week, do this.
-Plumb fuel system, brake system, axle and t-case vents - This next week, do this.
-Trim front fenders - Took me 45min.
-Exhaust - Stop crying, you have it easy.
-Build driveshafts - Took me 30min to cut down the front.
-Build OBA setup (or run ARB mini comp?) - Figure it out nancy, Adam already did this for you.
-Build seat mounts - Woopie, an hour with some little box tubing.
-Bumpstops - Bolt em in, or weld 'em on either way not long time.
-Limitstraps - Measure, order, wait, 5 min to install.
-Route wiring harness, patch into stock rear MJ harness for lights/fuel pump - Week after next, do this.
-Reinstall dash, new heater core, etc. - Week after next, do this.
-Build gearbanger - Week after next, do this.
-gear/assemble axles - Didn't we have a date for this? Plus assembly is easy and shouldn't take but 3/4 a day drunk to do both from empty housing to rolling.
Nothing all that crazy
