Carmelo, you have to find all the pedals and everything too right? I'd imagine all that stuff you could grab off a junk truck somewhere? Figured I'd just use whatever pedal I find off of whatever.
Prob need to make a custom crossmember (assuming you can't make a solid mount off of your current one) Stock one should still work from the looks of it with some holes drilled in it and obviously relocate it
Gonna have to redo the driveshafts I'd imagine as well. My specialty
What are you going to do for clutch MC/SC?For the ax15 obviously use the ones attached to it now. The MC can be reused with the T18 swap if I want or swap it out for something similar and just retain my clutch pedal that would already be there
