themangeraaad
- Halifax, MA
Edit: one of the uses for the 5' of 1/4" i have is shoulder braces to help hold the weight of some of the sh*t I hope to carry out... aka I want to show up and carry out an absurd amount even if I don't need it. Game on.
Though if the steel is useful to someone else I will sell it for what I paid and call it a day. Then I will go dig in Everetts for something cheap that I can make braces out of maybe. We will see.
Why are you doing the length of the roof? I feel like that would interfere with vision and/or pose a "your head could his this" item in the case of an accident. I plan on making mine almost like a center console for the XJ. Have something wide enough for a stereo head unit drop down in the middle of the rig. Will also have a switch panel above it. I'm not gonna stop ya and I do have some heavier gauge stuff (3/16 or 1/4) that is probably 4'-5' long (3" wide) that I could part with if I decide not to use it.I'll probably be using much heavier steel than that because the strip has to run the length of the roof (3-4 feet) without any support in the middle, I'm thinking 1/8 or 3/16 thick 3" wide strip. Probably won't bend very nicely on the brake, but it'll do fine in my vise, which I was planning on using. Feel free to show up anytime, just alert me first so I can make sure I'll actually be present or tell you where I went because I may be spending the rest of the day building storage shelves out of 2x4s, plywood, and cement blocks at my storage unit, assuming I get the axle in quickly.
