RWKHausSupply
- yorba linda, Cali
FYI Strange does custom make D44 35sp spools.
if it's actually worth it (which it probably isnt since a 60 isnt that much) we can probably have one made. if i do the cad work, it wouldnt be too expensive i dont think.I just got off of the phone with Tracy at strange who was very clear they not only do not do a 35 spline dana 44 spool, they do not do any dana 44 products.
i dont think it would be very expensive, but i agree off the shelf stuff is a better choice. if not for the spool, then for the axles.It's not worth it. We should use commercial off the shelf parts as much as possible to keep cost down, and spares readily available. Not that you would ever break a spool, it's just so much easier when you use COTS parts.
Do you really want anything from this axle?
I mean, the brake lines might be okay, possible the calipers. :laugh3:
it all depends on what happened to the carrier and such. if all that is bad is a bent tube, that can be replaced. but the labor involved is where the money will be spent unless you can do it yourself.
I'd bet the inside looks like Jello.
89sj said:...with 35 spline shafts and the housing bent that bad I wouldnt be surprised if the inside of that arb looks like something out of a "will it blend" video...
Chatting with Cal earlier today I said...
There is no way that anything inside that ARB is salvageable. Chances are the shaft on the passenger side is toast too.
k.
