Ray H
- Falling Waters, WV
SBrad001 said:Castor, camber, always get the two term bass-ackwards.
Castor is corrected by rotating the axle forwards or backwards though, correct? And castor is the angle that runs thru the hubs front axle/hub joints and angle that it makes runs down to the center of the front tires foot print? If this angle sharpens too much do to lifting, what exactly does it affect in the steering system? Don't we want to keep that imginary line as close to the center of the tire's footprint so that the tires 'want' to come back to center?
On a stock XJ, your caster (if I remember correctly) should be in the neighborhood of 7 degrees positive. That means that if you drew an imaginary line down through the upper and lower ball joints, it would be 7 degrees off vertical and the bottom of the imaginary line would be in front of the spot that the tire meets road. In theory, positive caster makes the steering more stable and less sensitive. When you lift, the caster gets closer to neutral and you must either extend the lower arms or shorten the upper arms. With higher lifts, there is a compromise because if you add too much positive caster, the pinion angle will be off and you get front end vibes.
