Sticky crap removal
mdl
natick MA
A while back I ran over a paint can (or a can full of somthing) because I had no other choice. It was allready flattened and all that happened was this puffy shit stuck to my jeep. This is such a frigging eye sore and I want to remove it finally. I've attatched pictures below but how the fawk can i get this shit off??
You're gonna lose your stripes no matter what you use so plan on it. Try a heat gun to loosen the stripes and peel slowly at a 90* angle to the paint. Clean up with Acetone or Goo-Gone.
The red/orange fade is a digital photo thing from the flash and the clear coat. It's not really like that, mine does it too.
I allready removed those rubber mouldings that run across the doors, the black right above them is a decal, the stuff below the mouldings is paint. I picked myself up a set of late model moldings because I figured these would be toast. Thanks for the suggestions.
There are a few things to try, in order of nasty.
Goo - gone
Greased Lightning
kerosene
mineral spirits
ATF
Brake Fluid
I've never tried it, but I have heard good stuff about caulking remover, supposed to remove old, dried caulk and stuff.
You should have some water with simple green in it and the hose nearby to get the solvents off before they eat your paint.
I'd try different things until the stick on stripes go, then worry about the finish. You might also call a body shop and ask their opinion.
Sometimes you can put waxed paper over a solvent to keep it wet and working longer. Good luck!
Prep-sol, sold in automotive body supply shops.
Sniggs said:
LOL not to get off topic but is there any cleaning product Billy Mayes DOESN'T sell???
Back to the topic, I've found that WD-40 is great for getting tar and other goo off the side of your jeep. I've also found that the armorall plastic wipes (the ones in the purple container) are great for getting tar and goo off also. Follow it up with a good wash after either of the two and your Jeep is back to looking good again.
Yep. I used WD-40 and a credit card to get a dealer sticker off a Mustang i had. I was pretty impressed. WD-40 and duct tape are the $hit :).
99XJSPORT06 said:
...and your Jeep is back to looking good again.
sorry but for some of us, our jeeps will never look "good" again.
I think he's been cryogenically frozen and reanimated. He has no control over the volume of his voice.
Yeah i thought about that after i submitted it...woops.
It's like every other commerical I hear it's: BILLY MAYES HERE FOR what ever product he's attempting to sell at the time.
