Mike1331
- Folsom, CA
recently :
rustys baja style fender flares...
fiberglass!!! sweet
recently :
you can do this with some dirt bike tires and sell them to me...
Its Original!!:wow:
i pulled the front diff cover tonight and all the steering .
some metal and shit in the gear oil, but the gears look good but the big ol washer behind the pinion gear was all mashed up as well as all of the ring gear bolts where so loose they were not even hand tight. its time to build a new front end with a full locker and get rid of the posi...but i am going to run it until then.
i welded the pass side uca mount back on, and i plan to truss that mount as well.
i need to pull the rear DS off and put a new CV setup on since the current one is a little jacked up and some of the material that holds the c clip for one of the u joints is pretty jacked .
and then it goes back to replacing some of the windows.
The "big ol washer behind the pinion gear" is the oil slinger. For that to get mashed up something is very wrong with your diff!
Maybe not this bad:
If you show up at SierraFest with a major KNOWN issue like that and it fails, just be ready for everyone to give you sh!t for "being that guy" forever for it!!! I am not telling you what to do or anything new, but when it comes to the invite only type of runs no one like to invite "That guy!" Hasta
Your 30 is just a tick'in bomb :explosion
ill stay in the back of the pack....
Our first mechanical trouble came when John (poomba) broke the rear yoke on his D35. CRASH did a little welding and he was fixed up. Check out the Chevy Z shackles.
The weather was as good as it could be, and the scenery was wonderful. This trail has a nice combination of challenging obstacles and great scenery, and we were enjoying ourselves. Unfortunatly, John's yoke broke again a little further down the trail. Here's Lee, Dan and John changing the u-joint in the driveline while a new yoke was being installed.
We weren't making the progress that we needed with this large a group, and it was getting late in the day for us to not be half way through the trail yet. We reached Winch Hill 2 around 6:30, and John broke his rear driveline for the third time trying to take the bypass. Most of the group kept on going, while Jon (Kaczman) and I winched poomba up the hill. We decided not to fix it again, and try towing him with only front wheel drive through the rest of the trail. I towed, and Jon strapped to me when needed, and we winched when we had to. Lincoln and Big Red were behind us and helped often with the strap, winch line, and stacking rocks. We popped the bead off the rim on one of the front tires three different times, caused by rocks and towing around tight corners. It was well past dark by now, which made everything a little more difficult. We got through the water crossings and up Winch Hill 3, but on a big double ledge both poomba and I got wedged between rocks and I broke a front hub. We don't even know what time it was at this point, probably around 11:00. We had to high lift John and stack rocks to get him clear and get the tension off the strap, then we fixed my hub. Here's me and John working on my hub.
We met up with Jes, CRASH and a number of the others at Winch Hill 4. I was able to pull John about 2/3 the way up the hill, but then it was time to winch. It took five pulls from different angles, two using a snatch block, to finally get him up Winch Hill 4. By this time it was 3:30 am and everyone was really beat. John stayed with his rig and made camp, and we finished the trail, pulling into camp at Meadow Lake at 4:40 am. No one had trouble going to sleep.
Most of us didn't break anything.
Great trip, although the wheeling was a little lonely for me since I was leading most of the time. Fordyce was one kickass trail, much more difficult than the last time I ran it. Way fun!
