ya i forgot to mention that was fully loaded with gear . empty its alot better.
anyway, steering kinda sucks. It drives straight on hwy5 long and straight, up in the mountains, its pretty squirrelly. picture a snake slithering through sand, it pretty much wants to do that . Its almost like I have too much caster and its wanting to return back and forth too fast. Its almost like I want a little wandering feeling back or something. we pretty much dialed in toe in, and I plan on checking caster.
on a different note, both my alternator and power steering pump died on mariposa road on our way to niagara rim on friday night at the same time.We drove all around stockton trying to find a PS pump and Alternator, finally got up to twain harte by midnight. alternator shot the bearing out the back and the shaft was full of play. PS was making horrendous noises, and ive riuoned PS pumps before and never heard this.
Rear driver side beadlock starting snapping bolts and losing air in jamestown arond 1130 pm friday night. Got all new bolts sat morning.
Also had lots of DW. So i ended up pulling off the hi steer arm, found out no matter how much we cranked on the bolts, it still moved way too much. like the arm would litterally slide back and forth. so we got a longer bolt and stacked the hiems on the driver knuckle. had to do this all sat morning after replacing alt and ps pump on the side of the road on friday night. ended up just camping by the clavey river for the night sat.
weird, in windy mountain roads it wants to almost constantly over correct and kinda get squirrelly back and forth, drives pretty straight on straight roads until I have to turn.
NO more DW for now.
wtf. is up the with the steering? new hub bearings, ball joints, driver side spindle, u joints, steering is all new. toe is good. I think I set caster to 10*. Im going to check. So tired...
to much seperation at the frame or axle side on the 3 link?
I am thinking at the moment:
stiffer front coils, and maybe drop 1-2.5" of lift off the front.
steering stabilizer
dial in caster (maybe give it less positive , maybe like 7*?)
