test drove it earlier tonight after centering steering wheel and setting toe.
I think some of the wondering i had before was from the fact that i was way toed in for some reason.
thing drives straight as heck, for what it is.
bled brakes some more, got more air out of the system.
but even better, the thing stops the 36s just great. the new brakes rock. I really like it. you can run the stock style steering with the WJ swap if you dont want to go all the way right away, ill go to full OTK later down the road.
rotors:
WJ rotors : 12" XJ rotors :11"
pads:
almost the same, WJ are a few thousands wider and longer, measured with dial calipers
calipers:
better design for the calipers to slide, and of course, the dual caliper pistons versus single caliper pistons, I can definely notice the increased clamping force.
also, I already had the WJ booster and master cylinder installed before this, and a ZJ proportioning valve, and all new 8.8 rear discs, so that helped alot.
