blondejoncherokee
- sacramento
had to do it.
my jeep is pretty close to starting out right now:
tnt long arms and belly pan
HP ford 9" rear detroit 4.88s 35spline chromos explorer discs
dana 30 front 4.88s true trac stock shafts alloy outer seals ruffstuff cover
5.5 rcoils
3.5 rustys packs with a couple stock leaves added and re shackles
edelbrock monotube res shocks up front
5150s in the rear
jks quicker discos
RE HD trackbar /mount/cross brace
currie steering
driver side "more" motor mount
zj box
cheap homemade sliders
cut up fenders and quarter panels and hood for vents
35" pro comp extreme terrains(the newer style)
waiting in the garage:
front 27 spline chromos (ten factory)
ruffstuff frame stiffeners
pass side "more" motor mount
8000lb winch
231 cae with wider chain widers gears and HD sye
finish 59 willys
homemade snorkel stuff
paid - but on order:
littleloenards 200$ winchbumper -cherokee forum
plan to grab soon enough
tnt truss/uca mounts/trackbar mount
heims and DOM to do OTK (sell currie setup)
2x6 for boatsides
longer run plans:
cryo d30 gears
37s
d300/231 doubler
internal cage
chop top from cab back and build a hard top and soft top
build a hi 9 front
5.5 rcoils
5150s in the rear
jks quicker discos
currie steering
zj box
8000lb winch
finish 59 willys
2x6 for boatsides
longer run plans:
cryo d30 gears
37s
d300/231 doubler
internal cage
build a hi 9 front
