yossarian19
- Grass Valley, CA
K&N cold air intake w/ Amsoil filter & pre-filter. Smog legal, depending where you get your test done. Fits 98 w/ 4.0 for sure, most likely all other 4.0's $50
Engine oil cooler w/ 1/2" lines. $20
PS cooler w/ 3/8 NPT ports, $10
Dana 30. Prepped for WJ swap that wound up on another D30. 3.55 gears, no sway bar mounts, reinforced UCA mount & LCA mounts are welded on the inside. New ball joints & brakes & bushings. $make offer
Set of leaf spring bushings I never got around to installing $20
RE 16xx track bar mount & IRO double shear bar. $125
XJ lower leaves for bastard-packing. Free.
I know there's some other stuff too but don't recall. Will add more later.
I'd really like to stress that I have no want / need of this stuff. If you want it, come get it.
