Lawn Cher'
- Westampton, NJ
Hey gang, haven't had time to play with Jeeps in several years, and am cleaning out the collection of parts now that I scrapped my last project.
Listing items here and will update as I find more stuff and/or items are taken...
XJ D44 w/ 4.56 gears and full spool, u-bolt yoke, thick cover, no brakes, very little use. $700
MJ D44 w/ 3.55 gears and mini-spool, u-bolt yoke, diff guard, Cadillac disc brakes, set up for spring over, includes Edelbrock IAS hydro shocks, u-bolts and plates. $700
D30 w/ 3.55 gears, ARB locker and cable disconnect, 1-ton chevy crossover steering, u-bolt yoke, diff guard, spare shafts, reinforced housing & LCA mounts. $500
(5) 33x12.5R15 Trailmark Radial D/T mud tires on 15x8 Bart black steel wheels, good tread on all and spare has never been used, 1 has slow leak. $300
JCR bumper w/ receiver, shackle tabs and winch mount, older style tube steel construction. $300
Milemarker 10,500 hydro winch, complete setup includes hoses and power steering cooler. $500
6" front suspension parts: Rusty's 4" coils, 2" poly spacers, RE drop brackets, Rusty's fixed LCAs & RE fixed UCAs, KYB Monomax nitro shocks. Parts are all well-used and control arms could use new bushings. $200
8" front suspension parts: Skyjacker 8" coils, Clayton's long arms w/ crossmember, Rusty's hydro shocks. Parts have never been wheeled, rig was built, parked and then later dismantled. $750
Awesome drivetrain parts: Ford T-18 transmission w/ Dana 300 adapter, D300 transfer case, Jeep T-18 bellhousing. I was going to use this in my MJ and put in Scout D44 axles (listed below,) but you could flip the D300 and use with Jeep axles. $900
Scout front and rear D44 axles complete drum-to-drum, may have 4.10 gears but unverified. $400 for the pair
Ford F150 hi-pinion D44 empty housing. $100
Ford early Bronco D44 empty housing w/ radius arms. $100
Scout D44 rear housing w/ shafts and a spare. $200
Ford early Bronco Dana 20 transfer case with the more desirable J-shift (think twin-stick,) complete with input gear. $100
MJ rear springs w/ extra leaf. $50
MJ rear drive shaft for longbed, built from thick wall tube. $50
Tom Woods CV-joint driveshaft (will update with length.) $50
PM or email [email protected]
Parts are located in Westampton, NJ 08060
No shipping but willing to meet partway as time allows.
