so ive found a few dana 44's for sell in my state.
norcalchris said:
thats what i thought. but how many waggys came with d44s?..i saw one at the junk yard and got happy, i was gonna pull the axles, then i got down there and they were d35/30.
major dissapointment
When we talk "waggies" we are talking about full size Jeeps, Wagoneers, full size Cherokees, J series trucks. Not the XJ sized wagoneers. The FSJ's will be full width so you need to swap both axles. Most all of them are D-44/D-44.
oh. got ya. can those axles be narrowed down, because there around 65 inches arnt they
Waggys are not full width, the rear axle is an inch narrower and the front axle is a few inchs wider than a XJ. I have a waggy dana 44 rear axle on my XJ and it is narrower.
Yep, anything is possible! Nothing money can't fix, but if its a trail rig why bother, run them full width. If its a stronger stock width axle you are after then your choices are the 29 spline 8.25(my favorite because they are cheap), the rare XJ/MJ D-44(expensive), or the slightly narrower ford 8.8 from a ford Exploder(mid 90's).
Anyone have a width on waggy axles (actual numbers).
-Alex
get an xj rear44 if you plan on keeping the 5 on 4.5 bolt pattern but if you wanna change the front out then try to plan ahead and match accordingly. just a thought
I for one can verify that a D44 came in the 87-90 Cherokee's. I have one.....
It's dirt and nasty, but it's a D44....
