kid4lyf said:
Rare, one time deal or common problem?
Also, how does it actually work?
Engagement easy?
Setup?
Can the lack of endorsement be considered a negative endorsement?
Jes is gone (wheeling again, that mofo) so I'll answer for him.
Overall, the OX's have been very good to him. The cable needs a bit of adjustment at first, as it stretches. The new spring loaded shifters are awesome, as they allow you to throw it into "lock" and forget about it. It usually locks with a 1/4 turn of the tire. The covers are awesome, very beefy, and for a 30 we theorize that they REALLY help with center section stiffness. Jes broke 8 or so front D-30 axles with his old D-30 OX installed, and it never had an issue, and it never backed bolts out. It's about to live on in another rock-abused TJ.
The 44 OX that backed bolts out was not machined correctly, of that I am sure. So as Woodrow suggests, I would tap the holes, clean them thoroughly, red loc-tite the bolts, and either tack weld (what I like, because I'm almost as lazy as Lazy Gary) or safety wire the bolts in. This same procedure should be used on ALL D-30 two piece carriers used in the rocks, as far as I'm concerned.
I would not hesitate to run an OX, they have proven EVERY BIT as strong as my much-loved ARB's, and are a bit simpler and idiot-proof.
Here's a cool shot of the OX cable guard Jes fabbed up last weekend:
