Comanchedude
- Cincinnati,Ohio
joshv98xj said:So what's the word on these kits?
I'm not looking for rock crawling steering, just a good upgrade for my DD and mild wheeler-
Who's been driving on them now for a little while?
Who's had success and how much lift do you have?
I read some about the TRE roll, does that vary depending on how high you're lifted?
Has the nylon spacer thing eliminated that?
Has anyone run the OTK on the driver's side with the flip insert?
Well if you have over a 4" lift the manufacture stated that you will get "roll"
And as I understand that is the case with all similar style systems no matter what the brand, it has to do with the angle from the steering arm to the link. I have the RR system installed at 6.5" lift and you can see the pass tre roll. I have driven on the road to and from my wheeling and didn’t feel the roll while driving or wheeling so in my case it does not affect my driving experience at all. Now I expect that roll will wear the part much quicker so I plan to make a spacer like they sell at JCR off-road and that will eliminate the roll. If you are running a lift under 4" you should not expect this "roll". The RR steering system is very hi quality and I am very happy with the system and recommend it to anyone that does not need an over the knuckle system. Basically for its designed purpose you can’t beat the system no matter how much you spend
