yossarian19
- Grass Valley, CA
My sainted mother bought me a set of Rota-Broach cutters for my birthday. If you haven't heard of it before, it's a hole cutter for sheet / plate material. Not a drill bit, not a hole saw. It's unique as far as I can tell.
First use was 7/16" holes into 1/4" plate mild steel. The supplied chart told me 900 RPM.
At 600 RPM, they screeched a little. Experimenting with feed rate (pressure on the drill press handle) I really punched it in there - and these things *devoured* the plate. Under 15 seconds per hole. The holes were round (not oval like I usually get with a twist drill) and with a very minimal amount of blow-through finishing the hole. Rota-broach recommends stick lube for these cutters; I was using 5w30.
With a more substantial lube & a press that could nail 900 rpm (mine is 600 or 1100) I'm guessing these perform even better.
As it is, I'm still VERY pleased with these tools. MUCH faster / cleaner job than with a drill bit. Definitely worth the $$ if you do much of any fab with plate or sheet metal. Available on Amazon, too.
