- Torrance, CA
What are the actual fuel pressure readings?
What if the fuel pressure is actually higher than is read? Faulty gauge?
The ECU doesn't read fuel pressure, there is no fuel pressure sending unit; you can only read fuel pressure from a fuel pressure gauge you hook up to the schrader valve on the fuel rail. With the fuel pressure regulator vacuum line hooked up and engine running it should read 32 PSI, with the fuel pressure vacuum line disconnected it should read a bit north of 40.
