- MilkyWay Galaxy
OMG, do you people read posts before you reply? LOL. He soldered them all, NO C-101 left!!!
I misread it. I thought he said he dreaded cleaning the C101!
This year while at KOH the MAP vacuum line came off, I was able to make it home after replacing the line but I have had issue ever since.
Would an exhaust leak upstream make both the O2 and wide band read rich?
I appologize if I am bringing up a question about something already answered, but I didn't see it. You say you changed all the sensors. Did that include the air charge sensor on the manifold just aft of the throttle body?
You never hear about it and most people don't even know it is there. You can check it with a simple ohmeter. It will royally screw with your mixture if it is bad.
O2 voltage has been verified back to the ECU and it is reading rich, less than 1 volt.
Just a note on the 2500, it receives information from the ECU thru a serial bus for most of the inputs and outputs. What it reads is what the ECU is reading. There are a few inputs that are direct, mostly relay state.
I replaced the MAP vacuum line yesterday because it broke, I installed a “T” at the MAP so I could plug in a vacuum gauge, the gauge is reading the same as the 2500. Yes the vacuum line is in the lower hole, I’ll put a little silicone on it today.
Now the MAT/CTS are something I am going to look at today, I have been so busy with O2, Sync, Map and TPS that I only did a quick check. The CTS reading on the 2500 is good and closely follows a thermometer in the radiator. The MAT was reading ambient with the motor off and follows the CTS only lower but I can see it warming up. I think I should take a very close look at these 2 inputs.
Water at KOH? Not this year! I did develop an exhaust manifold gasket leak while at KOH and that was my first repair in this mess. All test have been done after this repair.
I am running a Borla header, Bored TB with spacer, XJ Armor air filter adapter and 24# Ford Racing Injectors. This set worked well for several years.
I appreciate the help of the best Guru’s on the planet and will keep everyone posted.
What I am seeing is the Short Term Trim trying to lean out the exhaust but it can’t so the ECU defaults to open loop.
If the computer is reading a lean out of control condition it will switch to open loop!Read it again, the patent says that Wiki is right and the FSM is wrong (if in fact the FSM is reversed?).
One thing you missed, to add to the confusion, is that if the engine is running rich due to a leaking fuel injector (say on one cylinder) or FPR, the ECU may be fighting the leak by trying to run the rest of the engine lean, and if there is an exhaust manifold leak near the O2 sensor, all bets are off as to what the O2 sensor reading really means!!!
I am pretty sure (IIRC) that a high voltage O2 sensor reading on renix, is a rich, excess fuel reading. I will try and dig up my old notes later when I get time, but reread the bottom text of your patent post, it says high voltage is rich, excess fuel.
Bingo, I think I figured out part of your problem Please read post 70 and older on this thread, hell, read the entire thread:
http://www.naxja.org/forum/showthread.php?t=1012701
A low voltage is lean, NOT RICH!!!!
There maybe a typo, or confusing info in the FSM on this?
My comment in post 69:
Negative Mike. The Renix O2 sensor works in the opposite direction of most O2 sensors. Low is rich, high is lean.
