Rear bumpstop
90Pioneer
USA
I had a shop install a RE5.5" 6300 long arm kit mated with 33x12.5 Truxs tires.
Did some wheeling the other day and found out my rear tires rub pretty good when flexed.
Is there anyway to limit the rear travel, and if so, shouldn't the lift kit have came with something to do so?
Im not sure if your into doing stuff yourself but Get a chunk of square tubing and bolt it between ur frame and ur stock bumper stop to bring them down a bit more.
Depends where it's rubbing.
If it's rubbing the fender; trim.
If it's rubbing the inside of the fender well I wouldn't worry about it.
