- San Juan Ridge, CA
I am installing my new axels this weekend that I got from Turbobrick. they are a high pinion, non-disconnect Dana 30. It has 4.88 gears, 27 spline ARB, Solid diff cover, lube locker, truss, inner 'C' gussets, outer axle tube seals, EMS Dana 44 hub conversion, stainless brake lines, Iron Rock Offroad over the knuckle steering, IRO track bar, all steering is double sheared, Clayton lower mounts, stock upper driver side mount, RE upper mount on the passenger side, chromoly inner and outer shafts, Longfield 300m ujoints, with freshly rebuilt Yukon chromoly Super Joints.
And a Chrysler 8.25. It has 4.88 gears with a 29 spline ARB, 29 spline Alloy shafts, Solid diff cover with lube locker, IRO truss, WJ disc brake conversion with KJ parking brake cables, stainless brake line, raised shock mounts, diff skid with integrated traction bar mounts, with a slip and twist traction bar.
With the help of yossarian19 and a couple of other friends I hope to make short work of this unlike the other projects I have taken on which should read like a short story but end up being another War and Peace.
I will take pictures and post them when it's done.
