It'll be a somewhat daily driver (whenever I have a wee passenger, that is.)
Here's another couple questions...I've heard/read that there is a Jeep TSB (#23-029-08) that talks about there being a dealer-installed tether point for the child seat tether strap. The part ($60) is free and the install is free. Good deal, right? I think I got the seat nice and snug, so the only thing I need now is that tether ring/point. Yes, I initially tried to hook it to one of the cargo D-rings in the floor of the cargo area, but they pull the child seat either left or right, depending on which one I use. And the close rings and the far rings all work the same. This thing needs to be in the center somewhere in order to work.
And yes, I need it, according to the car seat maker and the state and the highway child safety seat folks. Oh...and the mom, I suppose as well.
The TSB says the kit/retrofit is good for 1989-1995 (I think...I know the 1989 starting year model is right) vehicles only. So, mine doesn't apparently make the cut. Which means Jeep won't install it, even if I pay for the labor.
The "anchor kit" is either part number 5003422AC or 500342AB. I wish I knew what was in this "kit", but no dealers I spoke to today (probably about 6 total) had any idea what was in it, or had ever heard of it, or had ever seen one/installed one.
I was also trying to find out HOW to install it. Is it a D-ring (or similar) that bolts to....the cargo floor? If so, does it only bolt into to a certain location, or can I put it anywhere?
Or does it bolt to the roof somehow (my preference, b/c that way I can USE the cargo floor without having a strap cut across it. Also, I can keep my OEM cargo tray without having to cut a hole in it.)?
Or maybe it bolts to the bottom edge of the open cargo door, so that I can use it with the door closed, and don't have to cut into the tray either, though it will probably fold the edge of the tray down?
All of this...I don't know. Since no one has ever seen one, I don't even know if I can put it on my 88 model, since apparently it's not listed in that TSB as fitting my model. Thing is, they didn't change this thing much in...20 years? Esp. the early years...why would it fit an 89 but NOT fit an 88?
I don't know, b/c no dealer has one to pull to see the instructions for the install, and no one has ever installed, according to dealers I called.
So...if you have a tether anchor point in your XJ, or have seen one, and know what it is, how it goes in, and where it goes, fill me in. Have photos? I owe you a beer sometime.
Oh...I also saw the photos posted earlier in this thread, but...can't tell what I'm looking at. Top? Bottom? Is that the inside of...the cargo door? I'm...confused as to what/where that is exactly.
