SolarBell
- Wheat Ridge, CO
From an information page on the Thunderbird SC (which my M90 is from):
Redline on the 3.8L V6 is 5600 rpm, the stock pulley is 3.3" in diameter. Stated max supercharger speed is 15,600 rpm. Drive ratio would be 2.786 to get that supercharger speed, which means a crank pulley around 9.2" (?!?!?)
The XJ has a 6.375" harmonic balancer and I put on a 3.0" pulley. That is a drive ratio of 2.125. At the 5250 rpm redline on the 4.0, I will get a supercharger speed of 11,200 rpm.
That is an output that is reduced 21.8% in raw CFM numbers (since the rpm of the supercharger directly correlates to CFM). Along with the 5.63% increase in displacement, I think the boost will be reduced by approximately 25%. That would result in approximately 9 psi of boost.
The Super Coupe's comes equipped with a 3.8 liter V-6 powerplant that is force-fed with an Eaton Corporation supercharger. The 8.2 to 1 compression ratio, combined with six computer controlled sequentially fuel injectors, completes the well rounded underhood package. While running at a maximum 15,600 rpm's, the supercharger provides 12 psi of boost and as a resultant it develops 210 bhp at 4000 engine rpm's. The engine develops 315 lb-ft of torque at 2600 rpm. The supercharged V-6 delivers ample power without much noise but an underdrive kit and a performance chip are available to boost the horsepower rating to 255 bhp.
