YELLAHEEP
- Littleton, Colorado
Considering that it was just offered on EBay and the last bid before the auction ended today was $10,501......which didn't meet the reserve........
You'd be correct.
Yeah, DJ and I had done quite a bit of discussing what would be involved in extending the cab, but we were looking at just adding the length of a set of 2 door doors. Got to thinking that if one were to take a hard hit '98+ 2 door and cut it at the windshield pilars, then across the floor pan just at the notch where the "B" pillar/door sil meets the floor and pull the rear away.
Then cut the Comanche in the same locations, but leave the unibody frame rails intact up to the lower control arms. Remove the MJ floor pan.
Remove the frame rails under the 2dr section, but leave the floor pan in place.
Roll the two sections together until the doors close on the back of the MJ cab and then take measurements to extend the roof, and the frame rails. Then you'd have to make some box steel sleeves to go into and between the frame rail sections.
Then the hard stuff would be to get all the sections made and welded in place to support everything - the roof being the hardest I imagine.
The reason I won't be doing this kind of project is that I don't have enough experience in unibody work or sheet metal (roof).
But it sure would be cool. DJ has a pic of what the completed project would look like..... he's posted it before in other threads.
This MJ is just plain SICK!...... gawd...... :loveu:
http://comancheclub.com/topic/27668-h3resqs-dream-mj-the-build-continues/?p=388686
wonder how much he's going to ask for it?
think he'd trade for my two door? lol
Personally, I call B.S. on you guys saying you could build it for $10-$12K..... no friggin' way. $30K? yeah, someone else got paid some labor to get to that valuation. But it'd take an easy $15-$20K to copy that truck to that standard. Sure, you could build "similar" for less...... but you ain't getting a twin of it for less.
That's what I'm saying. Chromoly shafts all around, spare chromoly shafts, fox coil overs, high quality Stroker build (a Golen is over 4K and I bet this one was more expensive) plus all the other parts. That's not even counting body work and paint. Sorry, you're not building that exact rig at the same quality for 10k$
Justin, his thread is gone. Must have not had such a warm reception to the price.
New thread.
http://www.pirate4x4.com/forum/vehicles-trailers-sale/1281962-90-99-jeep-comanche-eliminator-mj.html
I believe he'd get his $28K and possibly more if he took it to Barrett Jackson.
